Hi
I have just found a card in the gas meter box outside the house advising that the earth bonding is not sufficient.I have read some of the posts and it would seem that some posts suggest that I need to run a length of 10mm earth cable between the earth in the consumer unit and the gas pipe within 600mm of the incoming side but before a junction, whilst others seem to suggest the earth wire should be attached to the point at which the gas pipe enters building. Which is correct??.(if it is when entering building there is a problem in that the pipe splits up after leaving meter and enters building at two different points.Any advise greatly appreciated.
keefy22
keefy22
