D
Deleted2797112
Me again, didn't think I'd be back this quick! I wonder if anyone can advise please?
I'm replacing standard plastic light switches and sockets with some fancypants screwless ones which have a plastic template with the electrical connections mounted on a metal plate then a clip on chrome cover. The instruction sheet has a section for each different type of fitting in this range and the instructions for the sockets, spurs, heavy duty switches, connection unit, dual voltage shaver socket all say to earth the fitting. The instructions for the standard light switch don't mention earthing although the fitting has an earth terminal.
I've opened up an existing two-way light switch - the switch fitting has no earth terminal (because it's plastic?). There is an incoming earth in the switch cable coming from the light. This has been split and attached to a screw on the back box (which is metal) and the earth wire then continues out with the other wires to the next switch downstairs.
So given that the instructions are explicit about earthing everything else but not the light switch, does it need to be earthed and if so, how would I do it?
I got some great help here yesterday after I'd been struggling with a light fitting so thanks for reading! It's much appreciated.
