.... Say the incoming service pipe is plastic and cannot be bonded to earth, and at some point after the stop cock the rest of the pipework has been carried out in copper 15mm pipe work, ... So suppose somewhere in the property one of the copper pipes comes into contact with a live conductor, and since it is not bonded to a solid earth, so the whole pipework becomes live .... Could then an occupant of the house possibly get electrocuted if he or she touched any of the pipework, for instant touching a kitchen tap and at the same time manages to touch nearest electrical appliance that was properly earthed, such as a fridge, washing machine, an electric cooker etc etc.
In theory, that could happen - but, the same is true of anything metal within the house (window frames, filing & other cabinets etc. etc.).
What you are talking about is, technically speaking, 'earthing' rather than 'bonding', since it's purpose is to cause a fuse to blow, or a breaker to trip, (and thereby disconnect the electricity) if a live conductor comes in contact with the 'earthed' item - whereas the purpose of 'bonding' is to minimise differences in potential between any two simultaneously touchable things, without necessarily causing any protective device to operate.
So my view or opinion was that if perhaps any part of the water supply uses metal pipe it should be electrically bonded to an earth. This would remove the possibility of a live conductor accidental, or unintentionally making the metal part of the pipe work at live potential ....
One thing you perhaps need to consider is that there is a 'downside' (which is a sort-of corollary of the scenario you describe above) to earthing things that are not already earthed. Consider a situation in which a person comes into contact with a live conductor, or something which has become live - maybe due to a frayed/damaged cable on a vacuum cleaner, a faulty hairdryer/whatever, or whatever else. If they simultaneously touch an earthed tap, pipe, radiator or whatever, they will get an electric shock, but if that tap/pipe/whatever had not been earthed, they would not have got a shock. It's therefore not quite as simple a decision as you suggest, because by reducing/eliminating the risk of electric shocks in one scenario, you are also increasing the risk of shocks in other scenarios.
Returning to the scenario you described, in practice, even when the incoming water supply is in plastic, if most/all of the internal pipework is copper, then most, if not all, of that pipework will be 'earthed' by things it is connected to. Certainly anything to do with central heating or hot water (pipes, radiators, taps etc.) will be earthed, since the pipework will be in electrical continuity with boiler, pumps, motorised valves, immersion heathers etc., all of which will be earthed, and will earth the connected pipework. Even cold water pipes and taps will usually be 'incidentally earthed' - e.g. by being in electrical continuity with the HW pipes at mixer taps, by hot and cold taps being attached to the same metal sink etc.
Kind Regards, John
