I am about to replace a 1 gang plastic switch with a 1 gang brass dimmer switch. The mounting box is metal and has two earth wires going into it. Since i need to earth the face plate, i understand i need to run a single cable from the face plate to the mounting box.
However, i was wondering whether you could 'split' up the two earth wires, and have one going to the face plate and the other going to the mounting box. I'm not sure why you cannot do this?
Cheers.
Cheers.
