Earthing sockets
18 Jul 2008
Fife
What are the rules on earthing the socket box?
I have read such comments as 'if regulations require, attach earth between unit and backbox'
I am using plastic drywall patresses. I am in Scotland. Do i need to earth the patresses? Do i need to sheath the earth wire if needed?
thanks chaps!
no need to earth plastic patriss boxes.
Its considered good practice to earth metal back boxes but i think if there is a solid screw lug its not required, i may be wrong....
You have to sheath the bare copper earth wire with sleving.
thanks.
the triple gang switch that operates lights 1, lights 2, and a 5 Amp circuit is going to be a b*tch!
So many wires - so little space!
You'd need to earth a light switch back box if it was metal, however in this instance when using a plastic back box you just need sleeve each earth wire and join them all together in a piece of terminal block.
Have you connected all the earths to the earth terminal on the switch plate?
that's the plan, but i am still in the 'asking questions' stage.
the question was whether i should earth back to the box as well.
plan is to sleeve all three earths together, and wire to face plate earth terminal
Sounds good to me then :)
I just wanted to make sure you knew you must earth any metal faceplates.
