1)Main objectives of an earthing system are
Provide an alternative path for the fault current to flow so that it will not endanger the user
Ensure that all exposed conductive parts do not reach a dangerous potential
Maintain the voltage at any part of an electrical system at a known value and prevent over current or excessive voltage on the appliances or equipment
Different earthing systems are capable of carrying different amounts of over current. since the amount of over current produced in different types of installation differs from each other, required type of earthing will also differ according to the type of installation. so in order to ensure that the installation goes with the existing earthing system or else to do any modification accordingly, we need to have a proper idea of the present earthing system.It would enhance the safety as well as the reliability.
And by knowing about the earthing system we can also check whether it matches with the present regulations and standards.
2)Comparison of Earthing systems
Cost comparison
TT
requires proper residual current device to ensure protection which in turn would increase the cost
TN
saves the cost of a low impedance earth connection at the site of each consumer
IT
it also needs an additional protective device which increase the cost
Safety comparison
TT
A residual-current device can be used as an additional protection to enhance safety.
TN
An insulation fault may lead to a high short circuit current which may harm the consumer
IT
A single insulation fault is unlikely to cause dangerous currents but a second fault may turn the system to a TN system and cause more damage
hpe dis wl help u....
