Just moved into a new house (built 1950's) and it would appear it's had a rewiring at some point.
Examining the lighting circuit and used a mains testing screwdriver just to check for the live cable. To my surprise the light came on when I touched the Earthing wire as well as the Live.
Got my multimeter out and checked the voltage difference between the Neutral and the Earth and it would appear it's picking up between 4 and 5 Volts?
Is this normal - I thought the Earth should read zero? Any ideas how to fault find if this is indeed something to be concerned about.
