hi
ive just had my old lead incoming water supply replaced with mdpe pipe.
and from the rising main stopcock copper pipe is installed. i understand that this needs to be supplermentary bonded in 10mm earth cable back to the main earth block near the cu and that it has to be within 600mm.the question is my incoming water supply is about 4 metres away from the cu.
should i just run 4 mtrs of cable from stopcock to earth block or is there an alternative
