Hiya while i have the floor boards up i thought i would check here regarding earthing.
I found the attachments to water pipes under the sink in bathroom and one goes off behind the bath, which i will check when i get started, but... the sink one is not tightened up and is hanging free.
im Gathering this is a big no no!!! so i would like to redo the earthing if possible and if acceptable just tighten whats there the wire is green and yellow and looks quite new although last rewire was 18 years ago.
Ive had a read in wiki but still a bit unsure as no diagram that brings it home.
So im lost as to how many earths you end up with to the consumer unit.
do all pipe fittings get wired and then join up together to leave one wire as there is no way 5 or 6 wires will fit down conduit to enter back of consumer unit?
i have been advised that each pipe from teh boiler can go to each other but im not sure where from there.
Also please would i need to earth a stainless steel sink direct to the sink or on the water pipe to taps, so using access from bathroom area.
thanks OJ
thanks OJ
