Easy testing method for ring main wiring ?
7 Jan 2006
Sussex
I'm just about to extend my ring main for some new conservatory wiring but have a small query.
The plug I was intending to use to extend from is only a spur (i.e. one twin/earth wire connection. Directly on the other side of the wall to this socket is another socket, this time with three wire connections. I would therefore presume that this plug is on the existing ring main with one of the wires leading off it, presumably to the spurred socket on the other side of the wall.
Could anyone tell me an easy method of establishing which of the wires are related to the ring main, and which one spurs off to the other socket.... Also, on this same matter, as these sockets are part of a 10 year old extension to the house, how could I check that is is in fact a proper ring main and not just a radial circuit (as I can't verify who the initial electricians were )
Many Thanks
:D
you can find out if its a ring by disconnecting the wiring at one socket and using a multimeter on the continuity range. Not that there is anything improper about a radial provided cable size and fuse/breaker are appropriate.
you can find out which wire is which in much the same way, the ring cables will have continuity to each other the spur one won't have continuity to either.
