hi all
just discovered an easier way to lay click and fix laimante flooring
instead of following the instruction which say lay one board at a time and connect both the front and side of each plank as you go (spent many hours clicking getting one end of the line to click in for the other to pop out )
i found it easier to connect one whole line boards together first
then line them up to previous line of boards
click them in so the whole line is pointing up at the desired click in angle
referr to the instructions for this
then take your shoes off and slowly walk down the line of boards
slowly pushin them down and clicking them in place as you go
