Hi folks,
I have a modern (9year old) house, with a room at the top (gable) in the pitch.
in this room there is some wasted space into the eve voids
i have an ideal spot (hidden in a cupboard) for fitting a wall hatch on one side
however on hacking out a good hole i've found 2 obstructions
1. what appears to be a wooden vertical hanger directly behind the plasterboard, appears to be part of the roof truss, with nail plates at each end, 3x2
2. a diagonal brace (2 identical timbers layered) running from floor (gable end) of top room diagonally toward middle center of room)
ideally i'd like to cut both of these timbers, thoughts? I can easily reinforce point 1 above, and there's little weight bearing at the room at this point because it's still under 1.5m height in the room, so can't get much there even if wanted.
is the diagonal brace that i'm most worried about.
welcome thoughts and ideas please
Pete
Pete
