Eaves wall plate installation query
21 Jun 2015
Hi
I am building a small single storey lean two extension. My query relates to the eaves wall plate. I understand this is to be bedded on mortar on the inner skin of blockwork. Should the plate be cut to fit up to the inside of the return/gable blockwork, or should it pass through the gable and be cut flush with the outside face of the inner blockwork skin? Hope that makes sense. I cannot find any details on line that show this.
I thought it would be the first option so that the gable inner skin blockwork does not have a piece of timber to go over.
Advice would be much appreciated.
Thanks.
Butting it up to the inner face of the inner skin would be fine; what matters is that the wallplate is securely tied down.
Thanks. The plate is already in but crosses the gable blockwork and terminates on the outside of the blockwork. Blockwork is only installed to course below plate, so I could cut it back flush with the inside of the blockwork. My concern is the one thin course of raked blockwork not having a great bond where bedded over the timber - so would you say the best detailing would be to cut it back?
