Rush of blood at the critical moment often has long-term implications,,,,,
My wife has been asking for a new fridge-freezer and cooker (& sofa etc etc) but since we are doing Xmas this year the first 2 seemed most pressing.
Current cooker is a single electric fan-assisted built-in that was never quite the same after being dropped onto its upper rt corner when being re-fitted.
In order to save money after our extension, I re-fitted the kitchen units and the cooker and so far, they have been OK (ish).
So back to the future. Found a 2nd hand Stoves dual fuel on ebay being torn out of a kitchen not too far from here. Quick measurement identified that 1000mm is the distance of 2 existing units, one of which is under the 4 ring gas hob.
Having bid and won the cooker, it then occurred to me to check the existing cooker power point. Oops; ordinary 13 amp plug only. Consumer board is already overloaded and needs changing after aforementioned extension.
Need some advice here:
Still not yet seen the dreaded cooker, what should I do first?
1 Get electrician in to update consumer board and fit new cooker switch?
2 Collect cooker and assess its usefulness/remaining working life ie get a pro in to do this? Could just put cooker back on ebay and find a new built-in double oven (what my wife wanted).
3 Cost up: new work surfaces, electrician, new splashback and hood.
Will send in photos if this generates any interest,,,,,
Andrew
Andrew
