I recently had my immersion heater elements replaced after they stopped working. we had only used the off-peak one since we moved in (3 years ago) but had them both changed becaue they were both very bad (cracked and deformed). with both changed and tank filled we discovered the first problem;
1) connecting the boost element blew the house fuse (yes i have cartridge fuses and not trip switches, but thats a job for another time). So assuming there is one 13A fuse between the fuse box and the two switches; what is causing the one switch to blow while the other (off-peak) is fine.
2) We knew the off-peak switch has been working for the last 3 years (and i desperately needed hot water after 4 days!) so just connected the supply to the off-peak switch. the off-peak system worked for one night and we woke up to hot water. however since then we have had no more hot water. the light still comes on the switch at night suggesting the problem is somewhere between the switch and the element. we have switched the thermostat sections between the two elements and still no change. so has the cable gone wrong or did the brand new element go after just one night? or something else.
I'll describe how the system is wired because its odd (wrong) as it was probably all done at different times:
Fuse box divided into usual sections one of which is a 30A fuse which supplies the bathroom via another two 13A fuses divided into 1) Shower & Shower pump. 2) immersion supply for Boost & off-peak. Rather oddly the same 30A fuse seems to control the sockets in the bedroom too!
The Economy 7 is controlled by two switched that are "off-peak" and boost/peak/on demand. there is no timer suggesting radio signal controlled because it does seem to turn itself on and off during the night/morning.
Please help so i dont have to have the tank draine to see.
