Hello
I would like a bit of advice on Economy 7. Could someone help answer a few of these questions, please?
1. If you get Economy 7, when it switches over at night do all the rings switch over or is it only the timers outputs? i.e. does the primary ring main supply Economy 7.
2. I'm looking to have two larger S.Heater fitted in easy-wirable areas, these would be connected to the switched & 24hrs ring. However, access to other parts of the house would be difficult, so wanted to use a smaller <1.5KW heater on the main ring connected to timers - is this possible?
Thanks and appreciate the time.
Wayne
Wayne
