Hello
I have an ecotec plus 415 boiler. It has been fine until a few weeks ago. It suddenly turned off. There was a mains supply to it but the display was blank and unlit. I switched it off at the mains and turned it back on again. The display lit up but remained blank. I switched it off then on again and this time it remained unlit but two dashes appeared on the display. I removed the front of the boiler. I switched on the mains and moved the front panel forward and then it sprang into life. I carefully put the front panel back in place and the boiler continued to work.
A few days later it did the same thing and I rectified it the same way. Last Sunday it went off and was rectified by leaving the mains supply off for 10 minutes before switching it back on again.
Last night it went off and now it won’t go back on.
I thought there may be a mains supply problem to it but the display does do something briefly every time the mains is switched on. It usually lights the backlight or displays the two dashes.
Is there anything I can check or do or does it sound like a board or boiler problem?
Any help you can give will be appreciated.
Thank you
Thank you
