Hi again all, a little teaser you may be able to help me with?
First of all, this does not cause me a great deal of pain, more a sense of bewilderment !!
I had a new boiler (as above) fitted in September, linked to an existing Honeywell CM721 Wireless Programmable Room Thermostat and relay box.
The first time the heating was used in anger following installation was probably late October, and all appeared to work fine.
I have the programmer set at 19 degrees during the early part of the day, stepping up to 21 degrees at 3pm.
As the weather got a bit colder I noticed that at 3pm the boiler would start to do its job raising room temperature (lounge) toward the required 21 degrees but stop at 20.5 degrees. It can then take best part of 3 hours to finally get to 21. Sometimes, even after reaching 21, it can drop back to 20.5. I don't recall my old boiler (Biasi 428S) having this problem, I am sure it used to go up to 21 quickly and stay there.
I know the CM721 has a bit of clever trickery with getting near to required temperature and then cycling, but shouldn't it still get to the required 21?
Any responses are really welcome. Thanks.
SjH
SjH
