Hi everyone,
I've been browsing the interwebs on this matter a bit, but this forum is the only one that gives any answers, so here goes.
When we bought our house (in Flanders, Belgium) it came equiped with a Vaillant Combi Condensation Boiler. I've never found any paperwork on it anywhere, but using the Serial Number i've identified it as a VCW BE 296/3-5H. VCW 296 for short. I would estimate the age at about 7 - 9 years.
I've had to top up the pressure every now and then, but I thought this was normal.
About half a year ago there was a rumbling noise when the Central Heating switched on (= the pump rumbled when it had to pump around the house).
And this winter it happened quite a few times that we woke up to an icecold house and a boiler that somehow lost it's pressure overnight and decided to render an error-message rather than some heat.
A few days ago this started happening non-stop (could not keep pressure AT ALL) and water was leaking out of the housing of the boiler. Red alert.
I opened up the housing and found the leak to be on the underside of the pump (between the metal motorhousing and the plastic housing).
I've taken out the motorhousing of the pump and found that in the thin aluminium casing that surrounds the impeller shaft and is supposed to keep the watery bits seperate from the electrical bits there is a pinhole. And there is definitely water, rust and other muck in the electrical part of the motor. Also the shaft/impeller is a bit wobbly in my opinion (as in : it's in there loosely but not nice and snug like inside a bearing).
Sooo... pump broken, has to be replaced. I've tried to get hold of a plumber(s), but they either don't show up, or they give me the inmpression they know nothing more about it than me.
Sooo... I'm gonna have a go at it myself.
(see next post for rest of story)
