There is no water flowing when I turn on any of the hot taps.
The boiler is on and the central heating seems to be working well.
The loss of hot water has happened shortly after connecting a new 22mm cold supply pipe ( the old one was 15mm ). My first theory is that debris may have blocked something.
I have already removed/examined/replaced the aqua sensor, to see whether it was jammed, but there is no obvious problem there.
d.22 = 0 = No flow
No faults are showing on the screen currently, but the fault history shows a number of F.22 ( dry fire ).
The DHW did work during a couple of quick tests after the new pipe was connected. Since then there has been no flow at all.
The cold water is ON and has a decent pressure.
What else can I try before contacting Vaillant ?
d.22 = 0 = No flow
