Edging tape ?
10 Dec 2008
Jersey Marine
Have a large panel … being used over a hot tub, which is 5mm Foamex sheet (pvc foam), with a glued on 70 x 16 softwood ‘frame/edge.
Used a polyurethane glue, and also stapled through from Foamex onto wood.
Just thinking if I should wrap the edges much like they do on double glazed units, to help keep wood & sheet together, if so anybody know a suitable tape ? … Gaffa tape degrades after a wile.
ADHES Butyl Tape Waterproof Tape Aluminum Foil Tape Sealan Tape,5cm x 5m,for RV Repair, Window, Silicone, Boat and Pipe Sealing, Glass & EDPM Rubber Roof Patching, Silver (5cm x 5m)… https://amzn.eu/d/83Omscm
