I was looking at routes for some cabling i want to do, I live in a housing association property so while alot wouldn't bother the council, i need to be right so i can approach them with the improvement request... (of which wiring diagrams are required)
can i run coax & cat5 cable in ega tubing from the top of the house (coming out of the loft) down to ground level, then in through wall in kitchen, behind cupboards, behind tall freezer & into lounge? can keep cable in ega tubing if required in kitchen.
the path for the cables is 1.8m from the sink although there will not be any terminations, faceplates, connections etc. it is simply a route from outside to another room....
the ega tubing would be clipped to the wall & all pipework connections fully sealed. not sure this makes a difference though...?
thanks.
thanks.
