egr valve replacement
27 Nov 2007
HI
Has anyone replaced an egr valve on a citreon piccasso 2.0 hdi engine if so any tips fault code keeps coming up egr fault proberly needs replacing
cheers
pj
I had to remove my egr valve from my clio. Carbon build up causes them to fail. you can clean them depending on how bad . the clios are really bad for it.
once its cleaned or replaced the code can be removed from the ecu by a dealer or specalist
I have a 2L Hdi 306 (same engine) and a lot of people remove the EGR completely. I will be doing that and removing the cat to get me about 5 more bhp and increase mpg. Mines a 51 plate so this may be different on later ones.
you can clean them but its only a short term fix. If you clean/replace it you will probably find the light will go out after three turns of the ignition if the fault has gone.
