elbow and backplate
27 Dec 2008
Yorkshire
Can anyone tell me why I can't find a 15mm elbow with backplate? Compression both ends and preferably chrome.
I just want to join to 15m tubes at 90 degrees and support it on the wall.
Cheers!
Turnpike
Never heard of one. You could use a chrome wallplate elbow and a 15mm male iron or use a hospital bracket or holderbat.
Join together..
one of these
and one of these
I can't have a clip Micky as the whole pipe run is linked at one point with flex so the reason I want this wall plate elbow is to fix things.
It's for a rigid riser shower (with oval rail) and a free standing bath. Not a great solution but just one for the time being so I can have a shower.
I've just used a standard 15mm wall backet with some rubber in to tighten it and give some grip, but it's still not tight in place.
The two part solution looks like the best thanks.
Cheers all.
