RECENTLY I CHANGED A COUPLE OFF PLUG SOCKETS, SO I SWITHCED OFF POWER FROM MAINS, NOW MY HOT WATER WONT KICK IN WHEN I SWITCH IT ON,THE RADIATORS WORK FINE BUT NOT HOT WATER I HAVE A BACK BOILER BEHIND FIRE IN FRONT ROOM CAN ANY1 HELP PLEASE
Don't know your system but could be the actuator on the hot water divert -usually you have the option for heating and/ or hot water controlled by a valve that lets hot water from you boiler through the coil in your hot water tank. If you have a new style mains box possibly one of the circuit switches hasn't been reset? Otherwise check the valve actuator.
thanx for quick reply its really appreciated will try out ure suggestion,the boiler has been in bout 20 years but never had any problems b4 but things go wrong i suppose cheers .....ps think the make is thorn emi housewarmer si i will see if they website
