Hi All – Just a quick question about my Fuse box / electrics.. I believe it’s a Wylex NHRS6604. My Kitchen and my garage extension both run a separate ring and the electrics keep tripping in the whole house not the Lights just the electrical points. The main RCD switch in the middle of the fusebox is what trips not the individual MCB... So cooker. Fridge, microwave washing machine etc.. My main concern is the fridge obviously if it trips randomly during the day it will kill the fridge and the food in it…
The tripping happens very randomly.. Sometimes once in a month sometimes twice a week.. It happened last night and turned it back on at the fuse box. It would stay on for about 2 minutes and then trip off, and this time I was not able to get it to stay on for any more than two minutes. I did the usual check to see if anything was causing the problems. So I unplugged every single device, but still the problem remained. Unfortunately I can’t replicate the issue as it happens so randomly.. Not sure if weather is playing a part as it has happened when it rains but not 100% its due to that just a coincidence that it’s been raining a lot recently. I have outside connections for the lawnmower so I’ve placed a bag over the socket which has been there for the last few months so I know it’s not water getting into the socket..
Before getting an electrician does anyone have an idea of what it could be.. Could the breaker be at fault as it doesn’t actually trip just the RCD.... The only way I can make the system work is to isolate the kitching ring and keeping that off while the rest is switched on that way I’m assumed that the system will not trip.
Help much appreciated
Jag
Jag
