hi, problem with electric boiler means no hot water.
looking for help in finding the fault.
what i have done:
1. checked fuse box, fuse intact and reset
2. reset water heater switch
everytime it seems its the bottom immersion that goes bang and re-trips the fuse box.
Stage 2 was to:
check wiring on bottom immersion heater on the tank, all checked out, however i removed the centre part, think its the temperature cut off switch, dont see any problems so put back in. basically it is now just as it was before i started.
reset fuse, boiler starts, heats water four 2 hours, turns off, during the night at some point the fuse trips...again.
did same thing as above and same thing happens after a short time.
Stage 3 was to:
re visit the wiring, check earths are connected to pipes, they are. on further inspection i notice that the top immersion heaters cable looks discoloured. i think the earth wire was arcing to the unit as there was signs of it and wire looked burnt out, (earth?) i cut it right back and rewired.
retested, boiler starts heats and later cuts out, reset box and boiler trips immediately.
i dont think this is the immersion heater itself as it does heat up, do i just need to buy a new termperature cut off (middle bit) or any advice on what to check next appreciated.
cheers
james
what i have done:
Stage 2 was to:
Stage 3 was to:
cheers
james
