Good evening,
We're excavating the footings for our extension and have come across a cable buried about 18 inches down. The cable runs from a plastic pipe, through what looks like a length of cast iron drain pipe (!) and back into a plastic pipe.
The cable is thinner than my little finger, it's blue in colour and it may be armoured - it's difficult to see properly.
Both ends of the cable are buried under concrete so we cannot see where it comes from or where it goes to. However it does not appear to be fed from either the fuse box or an existing socket.
I assume it may once have supplied power to lights or a pond in the garden. Does this seem reasonable or can anybody identify what the cable may be?
As you can see it is right in the middle of the trench. If we can prove the cable is dead can we just cut out the middle which is in the trench and leave the two ends buried?
If so, what's the best way to prove the cable is dead before we cut it?
I have (hopefully) included some pictures: //www.diynot.com/network/Davey/albums/
Thank you
Thank you
