John Lewis Ceramic Hob - built by Electrolux.
Two queries:
1. connector on underside of hob show has 4 terminals - 2 live (L1), 1 neutral and 1 earth connection. Why is there 2 live connections shown and am I supposed to run a short length of cable from one live connector to the other? If yes, why did not the manufacturer loop the 2 together.
2. instructions state earth cable to be 2cms longer than live and neutral. Why? Earth is the first terminal in the connector and therefore needs to be of a shorter length than the live and neutral to fit within connector.
Both John Lewis and Electrolux will not give me any guidance although it does not fall within the building regs to connect a kitchen appliance to an existing wall outlet - only applies if you amend wiring and outlets in the wall. Thank you for your time.
Two queries:
