I have been asked to install a cooking range for my daughter and a little clarification of the wiring standards would be of help. There is a old style Wylex wired fuse consumer unit with a fuse rated at 30amp currently supplying a disused cooker point wired with 6mm cable. The consumer unit is located in a cupboard approximately 4 metres from the cooker. The range manufacturer says a maximum load of 15.6kw (all on) and the electrical connection can either be 10mm cable with a 40amp fuse or 6mm cable and a 30amp fuse.
1/ The range will be postioned next to the sink so I wiil earth the sink/taps to the cooker. ???
2/ Is it acceptable to put a main switch for the cooker in the cupboard with the consumer unit or must it be say above the cooker ???
3/ What kind of switch/mcb/rcd would be best to use either in the original consumer unit or as a additional unit ???
