I wondered if anyone could help. The indicator light on the wall socket started to go off so I had to keep flicking the switch and positioning it to stop the cooker going off. The light has gone off completely now and the cooker wont work. It is a double socket and the kettle is plugged in to the other socket and still works fine. I've had a little check and there is two red wires not connected. Do you know how much an electrician normally charges to check the wall socket and fix it. Thanks.
