Electric fire underneath tv help
8 Oct 2014
We put the electric fire on the lower part of the chimney breast and it is making under the tv quite hot.
Any recommendations to solve the problem without say moving the fire.
We want to pipit a floating shelf below TV but on top of fire to put sky box etc
Thanks in advance all
A heat resistant shelf is probably ok but the fire instructions should give the required clearances.
the gtee on your telly will more than likely be void if placed above a heat source
I shouldn't worry too much. Heat rises...
...so it will go past the TV and up towards that table on which the lamp is sitting.
Some of the heated air will simply curl around a plain shelf and still get to the TV.
If the shelf has a dropped front face fitted ( extending down below the shelf ) then some heated air will be trapped behind the dropped front and will have to go to the ends of the shelf thus away from the TV.
As some one who used to watch TV as a living, I can say that the TV is too high. The top of it should be slightly below your eye line.
The feature in the room can be the fire OR the TV. As a compromise I would move the fire down to about 6" of the floor and leave a 1/2 " slot above the top and bottom of it so some air can flow around the back of it to keep the chimney breast cool(ish). Then drop the TV by at least 1' and while you are at it, put a tube through the side of the chimney breast for the leads to the satellite box/VCR/DVD player, sitting on a shelf in the recess.
Frank
