electric hob glass issue - Bosch
13 Sep 2013
Hampshire
Good evening,
Im currently staying with a friend in greece, and the glass plate on the hob has come loose so is floating rather than level with the cooker top. I see a few very small sticky pads that may have held it down but not sure if these are strong enough to hold it down?
I guess the question is if you were to replace the glass top, how should it be fixed down? Should there also be a sealant and glue or just small double sided sticky pads? My hardware shops locally are limited so whatever advice can be given would be greatfully received!
