Can I replace this thermostat part easily (I assume that’s what it is)?
Yes you are correct also power the storage units as well which are coming on.do you know the night timer is coming on and providing power - I'm assuming a fused spur on that bottom elelment (cant see from photo) and if so - is the fuse OK in that
sometimes the night supply comes via another fuse/consumer unit - and also provides power for storage heaters?
No I don’t have a multimeter.As above if you have a multimeter and are competent to use it check if you have a live feed to immersion heater element.
It's actually far more likely the element has gone rather than the stat.
is there a separate consumer unit for the storage heaters & water heater - in case thats tripped
without a meter difficult to be sure , but i guess likely the element
Yep, I suspect so - hence all the questions ...... I have only changed a few in past ... lucky thenthey do often rip the cylinder, in attempting to get the old one out. Then the whole job becomes much more expensive.
