Electric Immersion Heater
22 Dec 2006
Wiltshire
Hi.
I have an electric immersion heater. It wasn't producing any hot water so I changed the thermostat a couple of days ago and it started to work again. Unfortunately it isn't working again. I presume the element is the cause of the problem.
My main question is:
For a new immersion heater do I need an electrician or a plumber? Sorry for the silly question!
Many thanks.
plumber, electricians wont want anything to do with the water side of things.
dont know what the waters like but if its soft e.g corrosive like it is down here,then i see a lot of probs with pinholed immersions causing the stat to blow. could need a new one, but for the price id get them both changed anyway just make sure you get someone compotent to take the immers out otherwise cylinder could crease. then your talking not so cheap
Thanks for that. I'm in Wiltshire, hard water according to the map on the back of my washing powder box!
As for competence, I am at the mercy of the number I pluck from yellow pages!
One other thing. Is this the sort of job where you call a plumber out and it all gets magically fixed the same day or is it a case of - you need the following bits and we'll be back after xmas to do it?
Pluck one from the Institute of Plumbing+Heating engineers then ;) Forget the Guild of Crafty Mastermen :LOL:
