- Joined
- 11 Oct 2024
- Messages
- 3
- Reaction score
- 0
- Country
I recently moved into a new apartment that has an LED electric mirror in the bathroom. The LED light wasn't turning on, so I disconnected the power and reconnected it. After doing that, the mirror worked fine. However, after I turned it off, it wouldn't turn back on. Instead, it just gives a quick flash, and I can't turn it back on again. When I disconnect and reconnect the power, it works fine again and stays on for as long as I keep it on. But once I turn it off and try to turn it back on, it doesn't work again unless I disconnect the power. The mirror also has a sensor and a heater inside. The sensor is working because I can turn the mirror on and off up to a certain point, but eventually it stops responding.
Do you have any ideas on how to fix this?
