Electric or combi shower??
1 Dec 2004
I am buying a new shower for my house and have been given lots of different advice about which system would be best.
Any advice would be gratefully received.
If you boiler breaks down then an electric shower will not be affected, This is one of the main advantages.
they are cheap to buy
Down sides are:
if you don't have a spare or redundant (e.g. disused cooker or immersion heater) fuse (MCB) on your existing consumer unit (fuse board), you need a new one.
The shower will need a pipe and a thick electric cable run to it, also a pull switch will need to be installed in the ceiling, so the existing decor may be compromised.
anything less than 9Kw will give a very modest shower (flow rate).
Even a 10kW is not great at only 4litres/min or so. Smallest combis are 24kW, which means 2.4 times as much water.
if u want performance go for the combi derived shower.....
if u think it would be nice to shower while someone fixes ur boiler go for an electric...
is the shower to go over the bath ? if so just change the bath taps to shower mixer type and hey presto..or fork out for a thermostatic one and be posh !!
Not going for the typhoon 25,000 litres a minute jobby then which not only sandblasts your skin but blows your genitalia off as well, seem quite popular in some foriegn hotels, or the 35,000 Litres a minute Micheal Jackson skin whitening model :p
