Electric or thermostatic shower???
27 Oct 2005
Avon
I'm about to install a new shower in our bathroom. I have an electric shower (10.5kW) and a regular thermostatic mixer shower at my disposal. In terms of cost effectiveness, which is better to install? I'm thnking that if i install the thermostatic, i will be using hot water from the hot water cylinder, heated from the conventional boiler (gas), but the electric shower obviously uses electricty to heat the water - so pint for pint, which is the cheaper option!!?
I'm assuming that the pressure for the two will be roughly equal.
I'm sure you didn't need to post this 4 times; I'll reply only once though.
Gas is a whole lot cheaper than electricity. In round terms, electricity it 6.5p/KWh whereas gas is 1.8 p/KWh. So approx 1/4 of the cost.
However, your electric shower will be almost 100% efficient. But your gas heated HW won't be - there are losses in the boiler (flue), the pipework (heat escaping) and in the HW cylinder (heat escaping).
It's hard to predict the overall efficiency of the gas heated water; but it'll be a lot higher than 25%, so, gas is very likely to be the cheaper option.
Not to mention the fact that wall mounted electric showers are fugly.
Computer egit... i thought i had posted it but couldn't find it, so kept on posting. Then realised i was actually looking at a slightly different page... hence, half a dozen postings!
As for the info, cheers. Gas is it then - i'll install the electric shower in the 'guests' bathroom!!
Thanks again.
Can i run it off mains pressure for cold, and hot water tank for hot - that will give me ample pressure won't it?
