Hello, Can anyone give me the straight facts before I employ a sparky ( so I dont get ripped off)
I want to connect a 2.2kw oven that is supplied with a 13a plug and the ignition for a gas hob.
There is a cooker switch (with socket) above the worktop approx 3m from the consumer unit on a 6mm t&e radial circuit with a rewireable 30a fuse. From the cooker switch there is 750mm of 6mm t&e to the oven connection unit under the worktop. Is it possible connect both the oven and gas hob ignition to the connection unit. Any ideas?
Many Thanks
Many Thanks
