electric oven size
19 Mar 2007
hi guys - before i purchase an electric oven..do they have some kind of dip at the back or are they completely square ?....the reason i ask this is because i have a hob fitted above in the worktop, the gas connection to the hob comes down a little and then is angled back towards the wall and down to the supply pipe...i measured the distance from the angle to the front of the 60cm oven housing assembly flush with the doors of the unit next to it and got 52cm....im thinking the oven housing have a depth of 60cm...wont the oven stick out of the housing....or is there a cut out or dip at the back of the oven to allow it to slide under the gas connection ?..ta
There's normally a section at the top that is "cut out" to give room for cabling and connection but best check it will fit still.
ta..was gonna order online, think ill have to pay a visit to currys or comet and have a look at the hobs...before i order one online...ta
