I have a three bed semi with a newly fitted en suite shower with a 9.5kw electric shower which is just about adequete and I feel that adding another electrc shower off the mains might cause water pressure problems so I am considering a pumped electric shower fed from the storage tank, probably a tritonT90si. What I really need is some feed back as to how good these are, basically the pro and cons of and do they not need to be thermostatically controlled as they are controlled by the pump?
Sorry to be so long winded but wanted to give you as much information as possible.
I have seen the comments within the forum where somebody has got a refund because the pumped sytem didnt work like a power shower but I intent to have two showers and worry that if they both come of the main it will cause problems......is this the case
