Morning all (please be gentle!!)
I recently moved into my first house, and replaced the existing electric shower with the same make/model (triton 8.5kw) for which there is a cooker style switch in the airing cupboard, next to the bathroom. Since changing the shower, there is occasionally a funny smell from the airing cupboard (with the cooker type switch becoming hot).
Having had a read of this forum, I can see that this should have a 10mm cable, but have a horrible feeling that its nowhere near this (and is the cause of the smell/heat)!
The following is on the cable 6242yh 2x6+2.5 sqmm altin 2007 - I'm hoping that (as I'm not an electrician) I'm being stupid, but is this a 2.5mm cable connected to my shower?!
Thank you!
PS. Fully aware that I need an electrician to replace cable if it needs changing/investigate if the existing cable is suitable.
Thank you!
