Hi All
Looking for some advise from an expert as I have had 2 electricians out with two very different views.
I have an 8.5 Kw electric shower, with 6mm cabling. The light on the wall switch started flickering, and eventually went out. Turned out the wires at the switch had started melting.
One electrician has advised me that the whole thing needs rewiring with 10mm cable from the main box to the switch and then to the shower (and I think he said a new RC switch too?).
The other said as it was likely a faulty connection on the wall switch. Just needs a new wall switch and repair the melted part of the cable. He also said that as it is only a few meters from main box to switch and another couple meters to shower 6mm cable is fine.
Can anyone form an opinion without seeing it?
I dont mind paying to get the job done properly, but at the same time dont want to destroy and re-plaster walls unnecessarily.
Thanks in advance!
Andy
Thanks in advance!
Andy
