Hey guys,
First off thanks to everyone for posting on this site it really has been invaluable reading.
I have recently bought a new electric shower 9.5KW and a new timer extractor for my on suite bathroom. The cable for the shower is 10mm so from past posts that should be fine but the existing MCB is only 32 so will need to upgrade that.
I would like to place the extractor fan on the same switch as the shower, so when the shower comes on so does the fan.
The fan is a low voltage timer fan, this one: http://www.screwfix.com/app/sfd/cat/pro.jsp?id=14750&ts=14840
So since the transformer is fed by 230v can I use the power from the cable supplying the switch which then in turn supplies the shower to power the fan as well if I get a sufficient MCB for both?
Thanks for any advice
