Electric Shower Front Cover Question
27 Dec 2008
Lancashire
One of the buttons on my electric shower has stopped working. The other 2 work fine and turn the shower On & Off no problem.
I've taken the front cover off just to have a quick look to see if the button was just misaligned or something but that's unfortunately not the case. I'll have to get an electrician to see what's wrong with it.
The first thing I noticed was that there isn't any sort of gasket or sealant between the front cover and the unit to stop water getting in! Is that normal?!?
It's a 9.5 Slimline Home of the Ultra similar to this at Screwfix
Thanks.
Many don't have a gasket, just a cunning system of overlapping edges that should keep the water out.
The instructions (on the Screwfix page) shows a schematic of the connections inside the shower. You'll need to look hard to find an electrician that could be bothered, or has the ability, to come out to look at it. Many are fine with banging in a few sockets but aren't able to carry out detailed fault-finding inside an appliance.
You see, a couple of decades ago there were proper craft apprenticeships. These days its "get a quick fix certificate in 5 days and you're qualified" :rolleyes: Don't get me started!!
What does the button do?
Yes, no sealant is normal, usually there is a gasket (although i'm not familiar with that make or model) but the showers are designed to not let water in. If there was no sign of any water inside, I wouldn't worry about it.
Thanks for the replies!
That's made me feel a little better/safer.
There are 4 buttons:
"Hot" - Slightly Warm!
"Medium" - Completely useless all year round!
Cold
Off
It's the "Hot" button that's broken, it worked fine this morning but nothing happens when I press it now.
EDIT:False alarm, tested the PCB with a multimeter. Turns out the buttons work fine, it was probably just a misalignment with the rubber cover as it works fine now.
Thanks again.
