Electric Shower Help
19 Jul 2017
Morning,
Anyone with any knowledge of electric shower faults?? Shower has been working fine up until yesterday when went to switch on but not functioning correctly
Pull switch is working correctly as light appears but once switched on the light on shower unit is fading before finally going out completely. All connections in fuse box, pull switch fine therefore I assume a shower issue...
I would suspect its the shower isolating pull switch. They have a habit of getting their switching contacts burned / pitted, so when the shower is operated and starts to draw current the contacts can't carry it anymore and nothing happens.
There is no need to operate the pull switch every time you use the shower. It is there for isolation when doing shower maintenance. Looks like you have worn out the switch.
Get a better switch.
Mine has been operated over 10,000 times and it is fine.
You wouldn't use the pull cord to isolate the shower whilst under load, so you shouldn't get pitting of the contacts.
It's not always operating the switch that causes arcing. I've known the isolator to arc under load. The shower was still working, but the arcing was causing radio interference. That was what drew the owners attention to it.
Well, I swapped our shower switch 18 years ago (MK) and it has worked fine since then.
And I switch it on and off daily.
