Hi all,
The house I rent has had the same electric shower for years now, and it's always had the same problem: if the 'tap' for the electric shower is on low the water will heat up quite nicely, but once you crank it up so the waterflow increases, the water doesn't heat up any more and goes near cold.
The electric shower is a RedRing SuperTX.
There's no issue with pressure because when it's cranked up to full the water comes out very fast.
Does anyone have any advice on what I could do to fix this? The knobs on the front indicating "HI" and "LO" work fine and it's currently set to one of the two labels marked "HI" but the temperature dial doesn't have any effect on the water temperature at all.
Thanks all!
Thanks all!
