The electric shower unit has worked perfectly for 13 months but know the MCB in the CU trips aftger about 5 minutes of use. The temperature setting of the shower has been turned down from high setting to medium but still breaker trips.
Shower is 9.5Kw, breaker is 40A Type C (Chint NB1-63) in CU as recommended by shower manufacturer !. Cable is 10mm2.
Before buying a new shower (as I suspect the heater coils could have gone faulty although the water temp does not alter) any suggestions as what else to check .
thanks
jimboy
thanks
jimboy
