Hello everyone. I have a few questions if anyone could please help me to answer:
I am replacing our electric shower (tritan ivory) with a new electric shower as it is not working, i suspect the element has burned out as the water runs just cold all the time and the pressure switch seems to be operating.
The shower is secured to a stud type wall, over our bath. It has a 15mm copper pipe rear entry straight into it horizontally. The new shower I have has different fixing holes, so I will have to use new fixings, but what type is best for this please? I am not sure exactly how deep the wall is and there is no access to behind it.
Also will it be fiddly connecting the pipe to the new unit?!
I am going to close off the power at the fuse box before starting work, close off the stopcock and drain water at the kitchen sink (lowest level).
Thank you all for your help
Best Wishes
James
Best Wishes
James
