Hi, I've struggled on with this problem for quite a while and finally decided to see if anyone could help out.
I have an electric shower - an Aqualisa quartz electric 10.5 - and I'm having problems with the temperature.
First of all, the water pressure is fairly low, this isn't particularly an issue, but thought I'd mention it in case it is relevant.
To the main issue...when I turn the heat up, over the course of a couple of seconds, the water gets hotter and hotter, to the point that it's uncomfortable (almost feels scalding sometimes), and then it will quickly goes back down to a normal temperature.
The problem is that the normal temperature that it goes back down to isn't hot enough for me (I like hot showers, hotter than people normally do!).
So somehow I want to raise the overall temperature of the shower. And possibly look at why the temperature suddenly rises so extremely for a second or two before returning to normal. (raising the overall temperature of the shower is more important to me though).
Can anyone suggest anything or point me in the right direction? I have no idea about DIY but this is something I'd like to fix.
Cheers
Cheers
